322 - IR Sensors - Which is which? | SatelliteGuys.US
pfef98
42
Pace, FL
On the front of the 322 there are IR Emitters and Receivers, but the manual doesn't tell you which little 'dot' is the emitter or receiver. Does anyone know which is which?
--Matt
--Matt
Block one with black tape and see if the remote still works.
Commitment Question
Superdish installation
