322 need 129 | SatelliteGuys.US
322 need 129
awcdish
59
SF Bay Area
I have a 722 and a 322 and started to have loss of signal issues the other night. The 722 had red x's but is fine now...but the 322 still has a red x on the 129 satellite. Is the 129 satellite all HD? I'm in the SF Bay Area. Is the issue causing the red x on the 322 the lack of any channels it can receive because 129 HD only? or is there really a possible line of sight issue? (There are trees around but I the signal clears them).
you should not need 129 for the 322.
but to be sure and safe, run a checkswitch on the 322 (im assuming the red x is from sys info menu 6-1-3) and retest. also, if you unplug the receiver, it will reset issues found inthe past with sys info, and the red x may go away.
Souhds like like your 322 at kone time was getting just 119/110 satellites do what Sca suggested and run a check switch, menu 6-1-1 although the 322 isnt a HD receiver it should recognize the 129 if thats the issue.
2 cables coming off dish 500
Programming access fee
