sounds like it's a legacy lnb or something. dishpro lnbs only has 3 of 3 switch tests! Are u using the right equipment?![]()
Smith,
If you are talking about a cable directly from 119 on the LNB. I tired that. I hooked the receiver up to a Dish 500 with a Dish Pro Twin LNB. At first, I had 119 to Sat 1 and 110 to Sat 2. The receiver identified the switch as Dish Twin and correctly found both Sats with good signal strength. Check switch was run and the receiver failed to download the software. After sitting for over three hours with the downloading screen, I stopped it. After that, I disconnected 110, per a recommendation on this forum, and tried with only 119 connected to Sat 1, same issue, the receiver failed to download even after 4 hours. So unless, you are suggesting something different than what I tried, it did not work.
Phil
Hi Randall,
The above test was with a Dish 500 and a Dish Pro Twin LNB. The receiver would not correctly recognize the Dish 1000.2. It called is Diseqc 41 and said it was unsupported. Which is why I tried it on another building which has the Dish 500.
Also I did the switch matrix clearing thing, which is how I got the 38 tests. With both LNBs disconnected, I ran check switch and the receiver ran through 38 tests. This was done prior to connecting 119 only.
Phil
Hi Randall,
I did that. Direct connection from the DP Twin LNB to Sat 1 on the receiver. Nothing connected to Sat 2. No separator, no switch. That was the setup I used with the Dish 500 after I cleared the matrix. The receiver would not download after 4 hours.
Phil
Limited time offer
