322 receiver, TV1 UHF Pro? | SatelliteGuys.US
breathe
92
okay, so i know this is possible, but i need some assistance. If i want to use a dish uhf remote for tuner 1, how is this done? I know a UHF Pro 4.0 remote is needed, but can i use the UHF Pro Key labeled 2? or do I need one labled 1 with UHF? im kinda confused.
take your #2 remote to your TV 1 location. Press Menu, then option 6, then option 1, then look for TV1 UHF Pro Setup. Select that, then go over to Enable on the next screen. Once you enable the feature, then on the right side select the "system info" button. Using the TV1 remote, press the up arrow until the box with the TV1 remote address is yellow. Once this is done, press record on your TV2 remote, and then your done
Team Summit General Assembly Notes
HDCP problems with 4.03?
