That model SWiM LNB is actually better than the SWiM-16 as it supports up to 21 tuners vs. 16 from the latter.In process of moving and currently have SWM16 and was wondering if a 21 tuner LNB i.e. 3d2lnbr0-02 would have any limitations or will it function just as SWM16 does but having additional tuner capacity. Thanks in advance for any insight.
Thank youThat model SWiM LNB is actually better than the SWiM-16 as it supports up to 21 tuners vs. 16 from the latter.
The only limitation is (if you copied the model no. accurately) that specific model LNB is not Reverse Band capable. So if you have or want 4K service, it should be changed-out.
Sent from my LG-H932 using Tapatalk
I well know that's the official line ...No, technically that LNB will support 13 tuners.
You only get the 21 tuner support when you hook up 3 genies to it.
Count on only being able to use 13
Genie and dual tuner receivers count differently.
For example 13 single tuner receivers, vs the example as you stated above.
Unfortunately there is no table showing what is what, so we go by 13 tuners as the rule.
I have been burned on this once where I tried installing 15 receivers.
Had to split the SWM and install a swm16.
So never again
From what I'm told it had something to do with the SWM channel spacing. Apparently if a genie has 7 channels they take less bandwidth then 7 separate H25's
Limited time offer
