4:2:2 Equipment | Page 2 | SatelliteGuys.US
4:2:2 Equipment
dashaund said:
This is true, however, I usually put my STB on standby once I get to the desired satellite, and then I can switch polarities when I change channels.
A PC attached to a big screen with 6.1 sound with a DVB PCI/USB device slaved to a STB is truely a beautiful thing!
PSB said:
The DVB World USB Box does 4:2:2 AND HD, I know I watch HD EVERY night with mine! My computer has very similar specs to yours!
The DVB World box will also move a DiSEqC 1.2 motor like the Moteck SG2100
The EASIEST way to hook it up is as a slave to your main STB (I also use the BEC )
The STB moves the dish to the desired satellite and then the signal is looped (With a short RG6 cable between both) into the DVB World USB box, the only downside being you are always on the same polarity as the STB. No big deal!
Well I don't use by BEC much anyway, so I'll just go straigt into the box, besides I need to make as shot a connection on this end anyway as I'm all ready going through about 350' of rg-6 just to get to the first box, so any C/Ku slaving is additional footage thru a splitter (and sometimes a disq switch).
But glad to here out of the box, similar specs, HD & 422 is easy, I need easy (incase I'm at work and wife needs to watch football!)
Got 78% signal level, 0% signal quality
Starting again!
