Per Ilya's advice I have reposted my original post in the general forum to attract for readers.
So I have been lurking around this forum for the past week, procrastinating at work. I have been searching this forum for an answer to one of the foremost questions on my mind. I have used the search function but still not come up with a firm answer so here goes. I have a HD ready 4:3 TV, (Sony KV40XBR700), and I believe most/all Voom programming, including all menus, are in 16:9. My TV does not have a stretch feature, not that I would use it if it did. Will all of the programming and menus have bars at the top and bottom? I read something about the Motorola STB that comes with Voom having a setting to accommodate 4:3 TV's but it was very vague. Any insight would be helpful, thanks.
Sean Moto replied to my question right away (Thanks Sean!!) I did have some further questions, see below:
Thanks for the response, I have a few more questions:
Quote:
Originally Posted by Sean Mota
Menus are displayed 16x9 or to fill the screen.
So all of the menus will have black bars top and bottom on my 4:3 TV?
SD: programming is mostly 4x3 with black bars on the side. Besides this there are two types that you get: SD programming in HD channels will have bars on the side but not at top or bottom. With SD programming on regular channels there are side bars but there will be a small little black bar at the top and at the bottom.
For SD programming: will it fill my 4:3 TV without bars on the side? SD on Regular Station: will it fill my 4:3 TV without Side bars and also top and bottom "litle black bars"?
Note: my Sony GWII on DVI input will not allow me to stretch the picture or zoom the picture but it will on component.
My Sony does not have DVI (only component) and it has no capability to stretch. Does the Motorola STB have a feature to adjust for a 4:3 screen?
Thanks again for your help!!
Any additional information or suggestions would be greatly appreciated.
