4 dish install compatible with which receivers? | SatelliteGuys.US
Spike
616
59
Suburbs of Milwaukee
Is there any way to tell which receivers will work with 110, 119, 148, and 61.5?
I purchased an 811, and followed the great instructions given, and ended up not being able to get all 4 satellites to work on the 811. I take it that this unit is too old to be affected in a positive way by software upgrades. Am I right? Or .... is there something more with the receivers that I need to consider before purchasing one that actually works to fit my need?
:cool:
The 811 supports 5 locations. Do you have another receiver to test this with? Also, some of us are of the opinion that the DP34/DP21 cannot get enough power from only using 1 DP21. The DP setup was never intended to run 4 locations. That is why the DP+44 has a power inserter. I was suprised when I found out that they added that cascade to the system.
Larry,
I only have one 811. I wouldn't mind buying another one, but, if it is going to be the same story that I'm facing now, I don't want to do that.
942 Install Question
Uplink activity for wednesday aug. 31 2005
