San Diego, CA 92124
Latitude 32° 49.206'N Longitude 117° 5.916'W
Sat Name Sat Lng Az(t) Az(m) El Skew
Telstar 12 15.0W 263.4 249.9 -18.4 -56.6
Intelsat 901 18.0W 265.0 251.6 -16.0 -56.8
Intelsat 603 20.0W 266.1 252.7 -14.4 -57.0
NSS 7 22.0W 267.2 253.8 -12.8 -57.1
Intelsat 905 24.5W 268.6 255.2 -10.7 -57.2
Intelsat 907 27.5W 90.2 76.8 -8.3 -57.2
Hispasat 1C/1D 30.0W 91.6 78.1 -6.2 -57.1
Intelsat 801 31.5W 92.4 79.0 -5.0 -57.1
Intelsat 903 34.5W 94.0 80.6 -2.5 -57.0
AMC 12 & Telstar 11 37.5W 95.7 82.2 0.0 -56.7
NSS 806 40.5W 97.4 83.9 2.5 -56.5
PAS 6B/3R 43.0W 98.8 85.3 4.6 -56.2
PAS 1R 45.0W 99.9 86.5 6.3 -55.9
Intelsat 705 50.0W 102.9 89.5 10.5 -55.0
Intelsat 707 53.0W 104.7 91.3 13.1 -54.4
Intelsat 805 55.5W 106.3 92.9 15.2 -53.8
PAS 9 58.0W 108.0 94.5 17.3 -53.1
Amazonas 61.0W 110.0 96.6 19.8 -52.2
EchoStar 3 & Rainbow 1 61.5W 110.4 96.9 20.2 -52.0
Estrela do Sul 1 63.0W 111.4 98.0 21.4 -51.5
Brasilsat B2 65.0W 112.9 99.4 23.1 -50.7
Brasilsat B1 70.0W 116.7 103.3 27.2 -48.6
Nahuel 1 & AMC 6 72.0W 118.4 104.9 28.8 -47.7
DirecTV 5 72.5W 118.8 105.4 29.2 -47.4
SBS 6 74.0W 120.1 106.6 30.4 -46.7
AMC 5 79.0W 124.7 111.2 34.2 -43.7
Nimiq 2 82.0W 127.6 114.2 36.4 -41.7
AMC 9 83.0W 128.7 115.2 37.2 -41.0
Brasilsat B3 84.0W 129.7 116.3 37.9 -40.3
AMC 16 85.0W 130.8 117.4 38.6 -39.5
AMC 3 87.0W 133.1 119.6 40.0 -37.9
Intelsat Americas 8 89.0W 135.4 122.0 41.3 -36.1
Galaxy 11/Nimiq1 91.0W 137.9 124.5 42.6 -34.3
Brasilsat B4 92.0W 139.2 125.7 43.2 -33.3
Telstar 6 93.0W 140.5 127.0 43.8 -32.3
Galaxy 3C 95.0W 143.2 129.7 45.0 -30.3
Intelsat Americas 5 97.0W 146.0 132.5 46.1 -28.0
Galaxy 4R 99.0W 148.9 135.5 47.1 -25.7
AMC 4 101.0W 152.0 138.5 48.0 -23.3
AMC 1 103.0W 155.1 141.7 48.9 -20.7
AMC 15 105.0W 158.4 145.0 49.6 -18.0
Anik F1 107.3W 162.3 148.9 50.4 -14.8
DirecTV 6 & EchoStar 6/8 110.0W 167.1 153.6 51.0 -10.8
Anik F2 111.1W 169.0 155.6 51.3 -9.2
Solidaridad 2 113.0W 172.5 159.0 51.6 -6.3
SatMex 5 116.8W 179.4 166.0 51.8 -0.5
EchoStar 7 & DirecTV 7S 119.0W 183.5 170.1 51.8 2.9
EchoStar 9/Intelsat Americas 13 121.0W 187.2 173.7 51.6 6.0
Galaxy 10R 123.0W 190.8 177.4 51.3 9.1
Galaxy 12 125.0W 194.4 180.9 50.9 12.0
Galaxy 13/Horizons 1 127.0W 197.9 184.4 50.3 14.9
Intelsat Americas 7 & EchoStar 5 129.0W 201.2 187.8 49.7 17.7
AMC 11 131.0W 204.5 191.1 49.0 20.4
Galaxy 1R 133.0W 207.7 194.3 48.1 23.0
AMC 10 135.0W 210.8 197.4 47.2 25.5
AMC 7 137.0W 213.7 200.3 46.2 27.8
AMC 8 139.0W 216.6 203.1 45.1 30.0
EchoStar 1/2 148.0W 227.8 214.4 39.4 38.5
Satellite Finder is (c) Copyright 2004, P. Lutus
CharredPC said:Basically, unless your reciever has the hookups for this, you'll be stuck on either V or H (hopefully not somewhere in between). I have one of those here, and it works for testing... but for a long term setup, I'd spend the $32 on one pf PSB's auto-switching c-band lnb's.
PSB said:Yes I adjust the skew as I move off the True South position, looking at your (GREAT) picture the "0" on the skew should be at the top for true south.
The other problem seems to be the same one I have, the C-Band LNBF is too high where it is at on the holder, so the elevation will have to be adjusted to hit the satellite signal.
I need to do some work on mine to get the LNBF as close to the exact focal distance but mainly the height.
caddata said:MrMilesG:
Haven't taken one apart but I'm told there are scalers behind the plastic waveguide covers on the offset LNBF's.
Limited time offer
