4dtv920 help | SatelliteGuys.US
4dtv920 help
sekaw
2
I just got a 920 downloaded install inst.and they don't show any wiring.I bought it off of ebay.and need to master clear.I believe I have the polarizer wires correct and motor wires problem is reed switch wires 3 posts myold 600 nextwave only had 2 posts marked ant and grnd any help would be appreciated.THANKS
I think that you should use pulse and ground. The +5 terminal seems to only be for saginaw actuators with mech position sensors. Any other hook up in the man. use the other two plus the sh for the drain or sheild wire.
