Correct it will move from 110 to 119. They seem to be shuffling things around in AK/HI and PR.
Why do they have the same national HD channels on both ciel-2 and echostar XIV?
Any idea what Dish plans to do with those empty spotbeans at 110 for PR/AK/HI after moving them from 110 to 119?
If you look carefully, those are on spot beams, which means they are being provided to places outside of the 48 states, i.e. Puerto Rico, Alaska and Hawaii.
doubt it..E15 is launching...........SOONSo where is E7 moving to ? Is it going to 61.5 ???
digiblur said:Correct it will move from 110 to 119. They seem to be shuffling things around in AK/HI and PR.
Is that a complaint?Looks we will be getting a lot of new HD!
Is that a complaint?(I didn't think so)
will Sacramento be getting PBS or CW in HD?
Does the new law require Dish to pull in the HD's from nearby DMAs where they don't carry the station in HD (PBS/CW)?
qualified noncommercial educational television stations located within that local market
you got one more
5262(6) - KTAL [MPEG4 HD] added to EchoStar14 119W TP 01 Spotbeam A13 (NA)(Texarkana, TX-NBC)
maybe digiblur can help you move?![]()
I see Wichita Ks appears to be linked, I wonder how long it will be until it says available?
There goes all the upstate New York stations. I wonder why they don't just put them all on eastern arc. Now all these folks will continue to need 2 dishes for HD.6540(34) - WIVT [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Binghamton, NY-NBC)
6541(12) - WBNG [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Binghamton, NY-CBS)
6542(5) - WBGH [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Binghamton, NY-N/A)
6543(40) - WICZ [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Binghamton, NY-FOX)
6544(46) - WSKG [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Binghamton, NY-PBS)
6551(7) - WWNY [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Carthage, NY-CBS)
6533(48) - WYDC [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Corning, NY-FOX)
6534(30) - WSKA [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Corning, NY-PBS)
6530(36) - WENY [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Elmira, NY-ABC)
6531(55) - WENYD [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Elmira, NY-N/A)
6532(18) - WETM [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Elmira, NY-NBC)
6520(20) - WUTR [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Utica, NY-ABC)
6522(2) - WKTV [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Utica, NY-NBC)
6523(33) - WFXV [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Utica, NY-FOX)
6550(50) - WWTI [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Watertown, NY-ABC)
6553(28) - WNYF [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Watertown, NY-N/A)
6554(41) - WPBS [MPEG2 SD 8PSK] added to EchoStar14 119W TP 01 Spotbeam A15 (NA)(Watertown, NY-PBS)
Limited time offer
