501 DVR not working | SatelliteGuys.US
501 DVR not working
usjeh00
3
I have a 501 DVR and it quit working. It cannot find the satellite signal.
I ran the switch test and it tells me there is a connection problem.
I swaped it with a 301 I have in another room to see if the connections were the issue but the 301 works fine in both rooms.
I can still access my recordings on the DVR with no problems.
Could this be a bad card. Dish Network wants to send someone out for at least $50.
Anyone know what could be the issue before I call for the tech visit?
Pretty much if another box works at original 501 location, the IRD is probably dead. Call and add DHPP for $5.99 / mnth, hangup and call back and it'll be a $29 charge. You might be able to ask them to just send it to you vs having a tech come out to do the same thing you can do.
It's possible if they send it to you they might not charge the $29 fee (that is you added dhpp).
Alot of it depends on how well of a paying customer you are, what package you have, basically how profitable you are, that and what mood the CSR is in.
Good luck.
Having Trouble Finding This Info...
Moving and Equipment?
