510 crashed while recording... | SatelliteGuys.US
jake_w
9
Last night around 7:33pm, I flipped over to Fuse (158) and started watching Loaded. At 8:00pm, I decided I'd record what I'd just watched for whatever purpose. Rewound back to the start and hit record. The red light turned on but the black bar at the top of the screen was blank and wouldn't turn off. The receiver wouldn't respond to anything so I was forced to 'soft' reset. That worked and when the system rebooted, I checked my DVR menu and it appeared it had recorded. BUT, it was showing the length was only 16 minutes. I checked the recording out, and it was much longer than that, ~30 minutes actually (but the "Time Left" is still wrong at certain points). From the point I pressed record (rewound to ~7:33pm) to about ~8:02pm (time of 'soft' reset) is all recorded.
Should I be worried about corruption? Should I just delete this particular recording and try again later (I know it will be on sometime later this week)? I've yet to experience having any of my recordings be deleted (although I did have the DST-timer related bug).
My 508 Is Working Better
Dishnetwork blasting its Contractors
