522 and the power button | SatelliteGuys.US
video62
385
It just occured to me... what does the power button do on the secondary (i.e. UHF) remote? It would be kind of bad for user #2 (presumably in another room, distant from the actual box) to be able to power the box off :x while user #1 was actively watching/using the box.
Sounds like something that should be a setup item in a setup menu somewhere.
Yea, I know we won't have the answer to this for a while since the 522s are not available to anyone yet.
This same concern would go for a model 322 receiver as well.
Well, ideally what it should do is, if the first tuner is not in use, then it should turn off the 522. If it is, then it'd just turn off the modulator like Scott said. Same thing for the other way around.
Ace said:
What if 2 people are trying to access the hard drive or the guide at the same time? Would the guide or hard drive load slower?
Well, yes, but only slightly slower... it shouldn't be enough to make anyone say "geez, I wish this thing would hurry up".
In fact, depending on how the software is written, the second person may get the guide quicker - if the guide data needed is now in memory (read fresh from the hard drive) and the second user gets their guide data from there.
In normal use, with two users watching live TV there will be two streams written to the hard drive, so I certainly hope the hard drive can keep up!
Stream data only takes a bit more than 18mb/minute and the hard drive in the unit is capable of at least 20mb/sec. So yes, i don't think it'd be a problem.
New Locals...
ESPN and Hockey last night
