522 Aquiring Signal | SatelliteGuys.US
522 Aquiring Signal
jlhugh
866
Austin, Texas, United States
Starting this past Sunday I can home and my local channels which are on 121 were cutting in and out and having a lot of pixalation. The signal strength is in the 80's on 121 and it stays constant. It does not go in and out like the picture. As of last night the receiver is stuck on the acquiring signal screen and it goes from 1 of 5 to 0 of 5. It just keeps going back and forth between those two. I have unplugged and done a hard re-boot and still get the same thing. A check switch goes fine, it finds all 3 birds. The only thing that I can think it might be is the LNB is going bad or the receiver is bad. All the other channels on 110 & 119 worked fine. Is there anyway to get it to quit acquiring signal on 121? If it would try to find 119 or 110 I am pretty sure that I would get my other channels back. I cannot turn the channel because it is stuck on the acquiring signal screen.
Anyone noticing major pixelation with their 942?
Newbie to HD...Looking for Confirm on setup...
