522 Guide Data Question | SatelliteGuys.US
drain69
17
I was trying to create some event timers for my local channels here in Sacramento. While browsing the guide it only shows what is on our locals one hour foward. This makes it nearly impossible to create event timers since I can't even tell what is on..
Any ideas??
How long has it been doing this or did you just get the 522 ?? It took around 24 hours before they all showed up for me and others have reported the same thing....
Charlie Chat Chat
Problem with DVI connection....odd
