522 on 1 tv | SatelliteGuys.US
522 on 1 tv
nkeeper
6
Can I use the coaxial out for tv2 and go to a coaxial on the back of my main tv. In otherwords I don't want to hook the 522 to a 2nd tv; instead use both tv1 and tv2 outputs to go to a single tv.
Thanks for the help.
Richard
Or use the composites, or mix and match any of the available connectors. Yup. If your TV does PIP, you can hook it up that way until they get single user mode working.
thanks guys. I assume I'll need both remotes handy?
I am using an ultimate tv dvr now, where I can record 2 shows while watching a third recorded show.
If I'm thinking right this should give me those same options...correct?
I think I would have to use both remotes and change inputs back and forth?
Thanks again.
Richard
Thanks again.
Richard
Yes, you'd need both remotes, unless you want to wait for them to activate the single mode, or possibly a third party learning remote can learn the two different remotes, not sure if that's possible.
Newbie Question: Connected Phone Line Required?
921 Software Update L1.46 Now Available
