522 Question | SatelliteGuys.US
522 Question
yes. go to TV 1 and use IR 1 remote pres menu 6-1-6 UHF pro setup. go to enable then go to System info. use IR 1 remote go to the left once and up to high light TV 2 settings grab UHF 2 remote pres and hold SAT button till all 4 light up then punch number 2-15 pres pound (#) light will flash 3 times use IR 1 remote pres one time to the left it will high light TV grab 2nd UHF 2 remote do the same thing only use different number so TV 1 and TV 2 wont inter fear with each other
and make sure other UHF receiver unplugged while you do that other wise you will change the UHF seatings on other box also and make sure none of the UHF remote addresses math
Thanks man... Works great!
Upcoming HD channels on Dish?
211 or 622
