5LNB: fascia mount vs. pole | Page 2 | SatelliteGuys.US
i have a 5lnb install for this coming thursday. my dish needs to be mounted on a pole. will the intaller have the poles or should i go out and buy them? do i only need one 2" pole? any advice is appreciated.
If they already know it is a pole mount, they will supply it. Are they aware of your situation?
dont listen to them....
a side mounted dish install on a house with the 2 support brackets will have plenty support for the dish, i just installed mine on the roof and didnt hit any beams, just the wood, and added the 2 support arms. The mast didnt even move when i tugged on it.
Good luck in heavy winds. The mount could well pull out of the roof.
Directv website Problems?
AU-9 Slimline Revision 1 Question
