D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/9/2010 3:25pm - 55 changes
Uplink Comparison Range: 06/09/2010 03:04P - 06/09/2010 03:24P
Channel Additions:
7738(19) - WUNM [MPEG2 SD] added to EchoStar10 110W TP 31 Spotbeam 05 (NA)(Jacksonville, NC-PBS)
7738(19) - WUNM [MPEG4 SD] added to Echostar12 61.5W TP 03 Spotbeam 5 (NA)(Jacksonville, NC-PBS)
8663(17) - WUNE [MPEG2 SD] added to EchoStar14 119W TP 01 Spotbeam A17 (NA)(Linville, NC-PBS)
8663(17) - WUNE [MPEG4 SD] added to Echostar12 61.5W TP 11 Spotbeam 8 (NA)(Linville, NC-PBS)
8763(36) - WUNP [MPEG2 SD] added to EchoStar10 110W TP 31 Spotbeam 05 (NA)(Roanoke Rapids, NC-PBS)
8763(36) - WUNP [MPEG4 SD] added to Echostar12 61.5W TP 03 Spotbeam 5 (NA)(Roanoke Rapids, NC-PBS)
286 - TWITR [MPEG2 SD] added to EchoStar11 110W TP 19 ConUS beam (NA)
286 - TWITR [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS beam (NA)
287 - EARTH [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (A)(Dish Earth-Live video from 110° Satellite)
287 - EARTH [MPEG4 SD] added to Nimiq5 72.7W TP 15 ConUS beam (A)(Dish Earth-Live video from 110° Satellite)
289 - REELZ [MPEG2 SD] added to EchoStar14 119W TP 09 ConUS beam (A)(Reelz Channel)
289 - REELZ [MPEG4 SD] added to Nimiq5 72.7W TP 07 ConUS beam (A)(Reelz Channel)
395 - SMC [MPEG2 SD] added to EchoStar11 110W TP 16 ConUS beam (A)(The Sportsman's Channel)
395 - SMC [MPEG4 SD] added to Nimiq5 72.7W TP 09 ConUS beam (A)(The Sportsman's Channel)
396 - OTDCH [MPEG2 SD] added to EchoStar14 119W TP 20 ConUS beam (A)(The Outdoor Channel)
396 - OTDCH [MPEG4 SD] added to Nimiq5 72.7W TP 05 ConUS beam (A)(The Outdoor Channel)
578 - TARAM [MPEG2 SD] added to Anik F3 118.7W TP 14 ConUS beam (NA)
9528(273) - GLVSN [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (A)(Galavisión (Este))
9528(273) - GLVSN [MPEG4 HD] added to Nimiq5 72.7W TP 03 ConUS beam (A)(Galavisión (Este))
19080 - MUNDL [DATA] added to EchoStar11 110W TP 01 ConUS beam (A)
19080 - MUNDL [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
19212 - OTST8 [DATA] added to Anik F3 118.7W TP 13 ConUS beam (A) (H)
Channel Removals:
296 - TWITR (NA) [MPEG2 SD] removed from EchoStar11 110W TP 19 ConUS beam
296 - TWITR (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 31 ConUS beam
4933 - CI (A) (H) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam(Crime & Investigation Network HD)
4935 - GREEN (A) (H) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam(Planet Green)
9448 - TMP63 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam
9448 - TMP63 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 03 ConUS beam
19211 - OTST7 (A) (H) [DATA] removed from Anik F3 118.7W TP 13 ConUS beam
19213 - OTST6 (A) (H) [DATA] removed from Anik F3 118.7W TP 13 ConUS beam
19217 - OTST5 (A) (H) [DATA] removed from Anik F3 118.7W TP 13 ConUS beam
Channel Moves:
9710 - 3ABN [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to EchoStar11 110W TP 21 ConUS beam (A)(3 Angels Broadcasting Network)
9710 - 3ABN [MPEG2 SD] moved from EchoStar6 61.5W TP 04 ConUS beam to EchoStar3 61.5W TP 25 ConUS beam (A)(3 Angels Broadcasting Network)
Channel Package Flag Changes:
653 - AFR24 [MPEG2 SD] - Anik F3 118.7W TP 25 ConUS beam changed to free preview (A)
667 - AFRMU [MPEG2 SD] - Anik F3 118.7W TP 14 ConUS beam changed to free preview (A)
751 - AFROM [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed to free preview (A)(Afrotainment)
826 - MDIAL [MPEG2 SD] - EchoStar11 110W TP 02 ConUS beam changed to Available
826 - MDIAL [MPEG4 SD] - Nimiq5 72.7W TP 31 ConUS beam changed to Available
Channel Mapdown Changes:
5347 - UNVSN Ciel-2 129W TP 32 ConUS beam mapdown of 59 added (A) (H)(Univisión (Este))
5347 - UNVSN Nimiq5 72.7W TP 06 ConUS beam mapdown of 59 added (A) (H)(Univisión (Este))
5348 - FTRAW Ciel-2 129W TP 32 ConUS beam mapdown of 63 added (A) (H)(Telefutura (Oeste))
5348 - FTRAW Nimiq5 72.7W TP 06 ConUS beam mapdown of 63 added (A) (H)(Telefutura (Oeste))
5562 - SMC EchoStar10 110W TP 12 Spotbeam 46/47 mapdown changed from 285 to 395 (A) (H)(The Sportsman's Channel)
9483 - SMC Ciel-2 129W TP 20 ConUS beam mapdown changed from 285 to 395 (A)(The Sportsman's Channel)
9483 - SMC Nimiq5 72.7W TP 03 ConUS beam mapdown changed from 285 to 395 (A)(The Sportsman's Channel)
Channel Renames:
6671(3) - WREG(Memphis, TN-CBS) - EchoStar10 110W TP 25 Spotbeam 14 renamed to KFVS(12) (Cape Girardeau, MO-CBS) (A) (H)
6672(5) - WMC(Memphis, TN-NBC) - EchoStar10 110W TP 25 Spotbeam 14 renamed to WPSD(6) (Paducah, KY-NBC) (A) (H)
4137 - TMP13 - Ciel-2 129W TP 26 ConUS beam renamed to TMP?? (NA)
4137 - TMP13 - Nimiq5 72.7W TP 32 ConUS beam renamed to TMP?? (NA)
4277 - TMP63 - Ciel-2 129W TP 20 ConUS beam renamed to GLVSN(273) (A) (H)
4277 - TMP63 - Nimiq5 72.7W TP 03 ConUS beam renamed to GLVSN(273) (A) (H)
5316 - TMP13 - Ciel-2 129W TP 26 ConUS beam renamed to TMP?? (NA)
5316 - TMP13 - Nimiq5 72.7W TP 32 ConUS beam renamed to TMP?? (NA)
5349 - TMP63 - Ciel-2 129W TP 20 ConUS beam renamed to GLVSN(65) (A) (H)
5349 - TMP63 - Nimiq5 72.7W TP 03 ConUS beam renamed to GLVSN(65) (A) (H)
Channels in the system: 7350
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.06.01
© 2010 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
Channel Moves:
Channel Renames:
