61.5°W TP-1 | SatelliteGuys.US
61.5°W TP-1
RickDee
548
26
U.S.A.
What is on 61.5°W TP-1?
I just got off the phone with Tech Support and one of the checks was Signal Strength on 61.5°W TP-1.
Mine is 0 (Zero), so I was told a Technician would come out to determine what is wrong.
My signal strength on 61.5 Transponder 1 is around a 12. They want to send a tech out, but after research I'm fairly sure its a spotbeam for local channels. If you get your locals, you should be fine.
I saw that TP1 on E-12 @ 61.5 is spot beams which do not apply to me, but I called back and asked and I was told that TP1 on E-3 is a CONUS beam and that I should be getting a signal.
Ciel-2 in Mexico
HBO Zone in SD?
