622 Color shifting | SatelliteGuys.US
622 Color shifting
mrhoni
88
3
My 622 is connected to Panasonic HD plasma (recent model). I have noticed that the color will fade out to a green tint and then the color will come back. I watch mostly recorded shows, so when this occurs I skip back and see if it repeats exactly. Sometimes it does but many times the color shift doesn't occur.
The 622 and TV are connected via component cables. So is my TV failing or even though I'm watching recordings, could it still be the 622?
Also, I have a 2nd 622 connected to the same TV via HDMI. I haven't watched much recently through that 622 and could do that more this weekend. If its OK, it might point to the 1st 622, but then again the 1st is connected via component and the 2nd HDMI. I could probably connect the 2nd to the component cables just to do a proper test, however I can't connect HDMI to the 1st as the HDMI has failed on that one.
Your opinion of my problem.
Thanks.
I noticed that I had a green color cast on all channels and so I had a simple idea and checked the connections. As I was pressing in one of the connections the color came back, so it appears I found the cause of my problem.
OTA channel listing with a 622
Just upgraded to the 622 (? about locals)...
