No. My 622 was updated to L4.01 some time yesterday WITHOUT me asking to be a beta testerI don't have the update yet. Are they just sending it out to beta testers right now?
Talon Dancer
Again everyone with a 622 should have the new software tommorow.![]()
The Dish Software Chart still shows L3.66 and L4.01 as current 622 versions.
According to that site you can update the software manually? Here is what it says on the above website.
Updating Software
1. Verify signal from Point Dish:
* Press the Menu button on the remote
* Select System Setup from the Main Menu.
* Select Installation from the System Setup Menu.
* Select Point Dish from the Installation Menu.
* Verify the signal bar is green and indicates "Locked".
2. Power the receiver off with the remote for 15 minutes to take the download.
I didn't think you could download the update yourself, or can you?
By the way I haven't tried it since I am currently at work as I read this.
When L4.01 is the only version listed for the 622, you can be pretty sure that the procedure will update you.According to that site you can update the software manually? Here is what it says on the above website.
Updating Software
I was confused as I didn't see any HD Mapdown features, but then I found out that you only see it on the All Subscribed list or the All Channel List. The HD Mapdown doesn't function in my personal customized list.
I'm trying to keep track on the EKB ViP622 Software History page.Is ther a listing of errors/bugs still in the 622 after the 4.01 update?
Limited time offer
