622 Programming problem | SatelliteGuys.US
halsan40
SatelliteGuys Guru
124
Palm Bay, Fl
I have tried many times to record one program while watching another. If I press record and then try to change the channel, it cancels the recording. If I set it to record say an hour later, it switches to the channel to the one I am recording and if you try to go to another channel it cancels the recording.
Can you record one channel on TV1 while watching another?
Thanks for your help.
Can't take it anymore!
Guide Data for Local Digital Channels ?
