622 Question.. | SatelliteGuys.US
622 Question..
htpc_dude
2
I am in the process of deciding between E* and D* and have a question about the 622. If you have it setup to feed 1 HD and 1 SD TV's when the second tv is not in use will the 622 automatically use the spare tuner to record on the background.
I guess what I am getting at if the second TV output is used is it dedicated to TV2 and can not be used for background recording when it is not in use
2nd dish installation...
Dish Installers and wiring help
