622 | SatelliteGuys.US
622
622 Power Consumption
If you look at the back panel of 622, near the AC power plug it says: "120VAC, 60 Hz, 120 Watts". I do not know exactly what it means, is it average, peak, minimum ?????.
That is only the rated or maximun wattage, I had my 622 plugged into a Kill-A-Watt for 10 days and it was always between 49 and 51 watts, on or in stand-by.. Also had my 42" plasma on the Kill-A-Watt for 10 days and tv is rated at 340w, avg. draw on it was about 200w maybe a little less.
Dirtydan said:
It is the same off or on about 50w
Hmm, I am finding that hard to beliive becasue when muine is idle it is cool and quiet, after some use the fan ramps up and gets noisy and the damn thing gets very hot.
I see about the same with mine plugged into a Monster power center with a meter on it.
Ever touch a 50 or 60 watt light bulb? :)
811 & OTA channel loss
Dish Network Can't Activate 721s...
