625 and DP LNB question | SatelliteGuys.US
stealth7g
3
Hello everyone one,
I have been running a Dish Pro 500 for a while now and decided change my receiver to a 625.
I have two coax cables coming off my DP Twin LNB. On one cable, I get absolutely no signal. The other cable peaks the meter.
I connected the single coax (with signal) to the Dish Pro LNB and terminated the other end to the splitter behind the 625 receiver.
I then entered the menu and ran a check switch. After exiting from the menu, I got picture on the TV and thought everything was fine; however, once I changed the channel, I got an error stating that there was a problem with the switch and I must run a check switch again.
To jump to the point, I am only able to view a few channels. Every time I change the channel, I get the check switch message.
So I call a local tech who tells me that I need a Dish Pro Plus LNB to get my 625 receiver to operate properly. Of course he has one in stock and was eager to sell it. I have no problem making this purchase if it will solve my problem, but I would like a second opinion (Yours).
Does the 625 require a Dish Pro Plus LNB, or could I just have a bad Dish Pro LNB?
Any input would be appreciated.
You can do two things here.
Unhook that splitter looking thing behind the reciever... that is called a seperator. and take your sat line that goes to the dish and plug that into 1 of the two ports behind the reciever where the seperator was hooked up.
Run a 2nd line from the dish and plug the other end into the other port behind the reciever.
RUn a checkswitch
-OR-
Get a DPP LNB leave everything else as is, run a checkswitch.
Thanks RC,
I'll remove the seperator and try it that way.
So the seperator requires the DPP LNB?
Because I get no signal off one side of my DP LNB, any chance it needs to be replaced? Should I receive signal from both sides of my DP LNB?
Yes the seperator requires the DPP LNB.
You should get signal off both sides of the LNB, but I have no idea of what kind of test equipment your using, nor how your doing it.
I'd just run a test piece of coax if you got one handy through the window if you have too, to just try it before you go off buying more things.
I removed the separator as you suggested and now I get picture on all channels. No more "Need to check switch" messages.
I've not gone back on the roof since, but I am sure I had no signal on one side of the LNB. I used a little analog meter. Maybe it was the small patch cord attached to that side that is bad. One day this week, I'll replace the patch cable on the no-signal side for further testing.
At least I have TV now. I am only able to use one tuner in the receiver, but you've provided me with the answers I needed.
Thanks again for your help.
Encore HD stunning picture quality
Duplicate Search Results Returned Bug on Vip622
