625 Modulated Output Question | SatelliteGuys.US
bondoo0
37
Hopefully a quick question. I'm hookin up the modulated output of a 625, and I'm wondering if the TV1 signal (channel 3 or 4) is included on the "home distribution" output of a 625, or do I have to use a splitter to combine the channel 3 and distribution output? I know on my 622, both TV1 & TV2 are sent out over the distribution outlet, but on the 625, I'm not seeing the TV1 output, just TV2.
Nope, you'll have to combine both outputs yourself - also keep in mind that the TV1 output (3/4) is NOT as high-powered as TV2, so depending on how many sets your sending it to, you might need to amp it first before combining it w/TV2.
Thanks, that was I was thinking, and thanks for the tip on the power difference as well.
How to upgrade for international channels
Apartment 'Pre-Wired' - Pre-paid an option?
