7200 Black And White Screen | SatelliteGuys.US
venus1
5
Hello, I need help with my 7200 dishnetwork receiver. I make a factory reset to my 7200 receiver and then some problem I have was corrected, but the screen lose all colors and right now only I can see all chanels in black and white. I need your help on how to find the way to correct and reverse the colorsto the receiver..
Regards,
Jose Lahoz
The 7100/7200 defaults to Black and White while it is being setup (perhaps because they figure you might be pointing it with a small TV or the like).
If you reboot/power off/pull smartcard it should go back to color when it resets.
Reedl
NOTHING HAPPENS, THANK YOU FOR THE SUPPORT. WHEN YOU TELL ME A REBOOT IS OPTIONS 32768?
:confused:
I Let The Ird In The Stream And Take The Colors After I Make The Prosess You Give To Me, Thank You Lot.
Ciao
EchoStar, Turner Reach Channel Agreement
What channel is CBS-HD?
