721 Signal Strength | SatelliteGuys.US
721 Signal Strength
lmarkley
2
Hi All,
I was wandering what Signal Strength you are getting, I am at 92% on 119 WEST & 87% on 110 WEST can you get 100% or is this what you all are at ?
Lynn
Your picture will be the same if your signal strength is 65 or 99 (its digital) so getting 100 isn't important (and likely not obtainable depending on which scale DISH is using in its software this month. At one time we were getting over 110 on some model receivers).
A GOOD signal is important to help prevent rain fade but if your signal is in the the high 80s and 90s you are fine as far as likely getting as good as signal as you can.
Tech Forum Summary 10-13-03
Dish News.... DHP / DVR Fees and More....
