722 Install question | SatelliteGuys.US
ibskiing
14
Currently I have a 622 and a 625. I would like to replace the 625 with a 722. Can I do this myself pretty easily? Is there additional equipment needed or can you just connect the 722 to the same cables going to my 625?
I remember needing an installer when I first rec'd the 622, but now that I already have HD, didn't know if it would be simpler this time around.
Yep... if you're already set up with a VIP series receiver, you're good to go as far as the Dish and cabling... the only thing you would need to replace is the video cable going from the receiver to the TV to get your HD picture.
Conflicting information
Reception Problem with 110
