T tribalcardboard Active SatelliteGuys Member Original poster Jul 11, 2012 15 0 Dec 15, 2013 #1 If an HD movie is recorded from the SD TV of a 722, would this movie be in HD if watched from the main TV?
KAB SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Sep 20, 2005 22,317 6,306 Fishers, IN Dec 15, 2013 #2 Yes.
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Dec 15, 2013 #3 Tuner 2 records in HD unless you have set it to a SD feed. Example Food network 110 has both a HD and SD feed if set to record the SD feed either tuner 1 or 2 will record it in SD.
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Dec 15, 2013 #4 All the tuners on the 722 are HD, the tv2 output is sd. If you record an HD program on tuner 2, playing on the tv1 output will be in HD.
