722 TV2 output | SatelliteGuys.US
722 TV2 output
Grandpa J
397
3
Camarillo, CA
722 TV2 output question. My daughter would like to connect her second TV to her 722 receiver. Her second TV has combo NTSE and ATSE (digital) antenna input, but TV does not seem to have separate cable input option.
The modulator screen on the 722 menu lists 3 options; Air, Cable, Off. So the question is - before doing a lot of rewiring - does anyone know if the type of signal from the 722 TV 2 output set on "Air" option would be recognized as either NTSE or ATSE signal by the TV antenna input?
If it is a newer TV, then you want to use Cable for TV 2 out. This will set the modulator channel to 73 on the modulator screen. Save this setting and exit out of the screens. On your daughter's TV, place the TV on channel 73. You should get a picture. If you have further questions, please let me know. Thanks.
Ready to switch from Directv to Dish right now
internet conectivity issues with hopper
