722k OTA UHF Problem | SatelliteGuys.US
shawreth
60
3
Hernando, MS
Needs some help all. My OTA on my 722k is only picking up UHF Channels. It picks up the VHF channels. I connected the TV strait to the antenna and it picked up all channels just fine. I rebooted the box and even did a check switch. This did not help get the UHF channels back. Any help or ideas will be appreciated.
Sent from my iPhone using SatelliteGuys mobile app
I don't have a 722 handy anymore but look for a menu option of HDTV setup and select that. You should then see an option for "Analog type" make sure that is set to "Offair" any other setting will not allow reception of UHF frequencies.
DISH and Apple
WB39 going black????
