722K with OTA Module locking up | SatelliteGuys.US
GreeneDish
SatelliteGuys Guru
131
20
Central VA
So here is the story:
About two weeks ago my 722K started freezing up once every two to three days..
By this I mean that:
When switching channels, the info banner would stay on the old channel, the picture would switch, and the sound would not follow a pattern (sometimes switch and sometimes not).
At this point, the remote would stop functioning and a reset was required.
Occasionally, even this did not work and it would take 4 or 5 tries to get it back.
When it took more than one try, it would start up like it should but as soon as the channel was changed it would lock again.
I checked my temps and everything looked good except for the max (90/118/138).
Just in case, I removed the doors to my cabinet but the problem continued.
Stumped, I actually started tracking the problem and found that it only happened when switching away from a OTA channel.
After pulling the OTA module, I have not had any issues for three days now.
Based on this my assumption is that the OTA module is failing which brings up a few questions:
1. Since I purchased this separately from DISH is it covered by the service plan?
2. Is this a known issue that will repeat with a new module.
3. Would the Ebay Dual Fan unit help with this or is it temperature independent.
I am planning on waiting till the end of the week to confirm it is the OTA module before contacting Dish so I am just trying to collect information for now.
Thanks,
Interesting. I just installed an OTA module in my 722. Now if I watch tv for an extended time, I think only on the OTA channels the remote will not do anything after a certain amount of time. I hit the guide button and nothing happens. Try to channel up or down and nothing, hit the info button and nothing. The only way to get it to work again is to either hit the reset button or unplug the unit and plug it back in. This only started happening since I installed the OTA module. Has happened twice now and both times I was watching an OTA channel. Nothing happens at all, it just keeps showing the current show I am watching as if the remote has not been activated at all, can continue to watch the current channel as long as I want to no freeze up or anything perfect picture etc... Went to change channels or look at the guide and no response at all. Only way out of the current channel and to get the thing working again is to hit reset button or unplug the receiver and wait for a reboot.
I deleted all channels and unplugged the module and reinserted it after I did a reboot on my receiver: unplugged it and replugged it back in. Any problems with the ota module stopped when I did that.
I've noticed the same problem. Must be a feature they added free of charge in software version L750 since I don't remember it happening with older software versions.
+1
Same issue here. Never happened before L750. Your module is probably fine. Delete/Re-add is probably a waste of time. Just have to live with it until a new version comes along.
Another "me too" - same symptoms and required reboot for resolution. It started one or two weeks ago, and I just recently confirmed that I am running L750. Thus far, it hasn't locked up when recording something, but I'm sure it's only a matter of time--and then I'm likely to switch from irritated and annoyed to furious.
Yep, I'm having the lock-up situation when first tuning to an OTA station. The banner stays on the screen, receiver unresponsive to all commands requiring a reboot to get things back. Only started happening since L750.
I will have to check my software version but suspect I am up to date.
Based on the responses, I think I will wait to contact Dich about a replacement and see if they send out a fix first.
At least I still get my locals just not in HD.
I noticed this happened recently when I was in dual mode. I rarely use dual mode , but I used it this last weekend and sure enough lock up and reboot. Now in single mode I tested it vigorously and no lockups or reboots. So it must just effect dual mode.
Not for me, I keep my DVR in Single Mode and it still happens to me.
Several years ago when viewing OTA with a 722, when signals got weak and intermittently dropped out, the software would crash as described here. The unit would usually automatically re-boot within a few minutes. It went away after a while probably with new software. You all should complain to Dish anyway under the squeaky wheel-grease concept.
My 722k started locking up as soon as L750 came out. Not sure it has anything to do with OAT though.
What happens is that my remote as well as the buttons on the front of the unit will do nothing.
I know my remote still works because it will still control my TV volume just fine.
When this happens (like it just did tonight), I have to do a power button reset.
So far I have had to do this about 8 to 10 times since L750 reared its ugly head on my unit.
Try to unplug the 722k and leave it for a couple of minutes and then plug it back in. It is called a hard reset. This is needed sometimes after a software update to help it work again.
An OTA signal that is dropping in and out presents challenges to the decoding. It is this that is crashing the operating system and causing the lockups. It's the software.
If you have a 1000.x Dish. ignore the info on the point screen for Dish 500, etc. It's outdated. align the Dish till you get a green locked message on the strength bar and the name of the sat. Then press Done.
Hopper Freeze Tonight
Tailgater Questions for the Dish Team
