Need some help with my R22 intermittently loosing signal strength and displaying 775 error. I had to install a new dish as roofers threw away my old round 18" single LNB dish. I found a SL3S4NR4 LNB and put it on one of the large oval shaped dark gray dishes (don't have dimensions right now) with the multi angle (HD) adjustments and ordered a SWIM to connect the two. 98% signal strength. Are these components compatible? I am unsure of the cable type connecting the LNB to the SWIM. Does that matter? It didnt have any markings on it. No problems with this error until had to change dishes. Thanks for the help.
