811 reads TP but won't lock on signal screen | SatelliteGuys.US
Mr Tony
3,373
14,811
Mankato, MN
Well, the weird fun of a Dish customer continues :)
My locals are on TP12 on 110. When I go into the signal screen and select 110 TP 12 the bar goes up to 80 but it says "Wrong Satellite-Unknown" and is red
Yet my local channels come in.
The other spotbeam TP for my area (TP4) locks right away and the bar is green and it says "Spotbeam". The other TP's work fine and are green (except for a couple spotbeams I am barely in but not enough signal to register it)
I have tried the soft reboot, hard reboot but nothing
811 with a DP34. This did it when I had Legacy too
Should I not worry about it since my locals do work?
My 811 had that problem among numerous others. It never seemed to cause any problems though. I had it on DP LNB with a DP34 and DPP44, nothing seemed to make a difference. I lived with it until I got rid of it.
yep. 3 DP Duals into a DP34
its the only TP that does that....but the chanenls come in so I'm not complaining
Another Court Loss for EchoStar, August 15th RIP
Closed captioning in HDNET 9422
