87 W modulation/compression | SatelliteGuys.US
skipticum
40
ottawa
I just acquired two 6' mesh dishes for c-band (stationary) setup, and I'm trying to figure out which two sats I should point them at. I like the muxes on 87 W, but I'm not sure my DBS (digital) receivers are up to the task. Lyngsat shows Retro TV Network as DVB-S2/8psk, but it is not clear to me if the rest of the mux at 4080 H (tp. 19) is also DVB-S2/MPEG-4 OR DVB-S/MPEG-4. One of my receivers can do MPEG-4 (compression) but only with DVB-S (not DVB-S2). I need your help to clarify, and advice on the best two sats for my two stationary dishes. Thanks
both of the Retro TV muxes are DVB-S2 so you would need a receiver that can handle it.
Looking at Lyngsat if there is more than one chanel in a mux (group of channels) the 1st line is the company and the modulation (in this case DVB-S2 8PSK) and the channels below it are the same.
How to lift a 300 lb schedule 80 pole yourself.
Looking for a dual feed chaparal.
