The Pansat 9200 has a DVB-S2 add on module, and supposedly the new AZ Box thing has one available.
you may be able to watch some of these without the turbo board anyway.
You'll need TC 8PSK module for those occasion ITC.
My statement was based on the fact that I have a sonicview hd8000 without an add-on board. When blind scanning a certain circular bird I found some unscrambled hd channels (mentioned in the wut section on march 29) and was able to watch them.
Sounds like a challenge to me....lol. You are right, there is a lot of info that should be compiled to a single source, or at least the same thread, and there are a lot of guys here that have the experience with the available equipment that their contributions would be essential for a successful FAQ on the subject. Making reference to available equipment, and current publicly known and available channels, with details on mode, freq, etc, would remove the discussion from the abstract and give it some real world tangable references for us that are dumb as a box o' rocks on the subject. (I'm not implying you are in that box zamar, but if you think you should be, just tell me to move over and climb in....lol)B.J.
Could you explain in details for unfamiliar, why and how using a Twinhan DVB-S (or S2 ?) card installed in one's PC with sat signal output controlled by TSReader program, and connected to that PC Popcorn Hour Media Player (via USB or network ?), it's easier to get QPSK modulated DVB-S MPEG2/4 HD channels on your HD Monitor than using only a PC with DVB-S Card?
Also, don't you think guys, a detail FAQ Thread in this forum's FAQ Section is a must have on this quite complex but important for most people topic? It should also have an updatable list of all HD channels, one can legally get in North America sorted by sat DVB standard, then modulation and encoding type.
The Twinhan {1020a} is a DVB-S card. Using TSREADER, I can stream either SD or HD, and either MPEG2 or MPEG4 over my 100mbps LAN. I can play the streamed video either on another computer {SD or slow HD MPEG2 only due to slow PCs) or to my ROKU HD1000 {SD or HD MPEG2}, or to my PopcornHour, which will take SD, HD MPEG2 and MPEG4. This is easier FOR ME, or actually a necessity for me, because to display HD on the computer, you need a pretty fast computer, and the computer I have my Twinhan card on is only 1.9 GHz, ie not fast enough for anything but low bitrate HD.B.J.
The RF layer of the DVB-S2 signal is divided into physical layer frames that do not need to use the same coding and modulation.
Not only that, the same transponder could have SD TV using DVB-S and HD signals using DVB-S2.
fixed thread..the op was a hacker so after bannign him it deleted his posts (and threads)
sorry for the issue
HMMM........ Guess he blew it in another thread or via pm to someone. I didnt see anything in this thread to indicate his intentions. If anything it seemed he was looking for info on how to rx anything that wasnt illegal, at least in this thread.fixed thread..the op was a hacker so after bannign him it deleted his posts (and threads)
sorry for the issue
Prime example of heed the warning or pay the price.the latter one![]()
Limited time offer
