921 question about screen size. | SatelliteGuys.US
sparker
178
Cedar Springs, MI
My widescreen TV has a bit of overscan in 16x9 mode. I can't correct that without entering the service menu thus voiding my warranty. Does the 921 have any kind of a feature to do that kind of a thing. Basically shrinking the sides and the top and bottom a little? Sorry if this has been answered already.
No. There is absolutely no way the manufacturer of your TV can tell if you entered into the service menu. Just be sure you know what you are doing, or have the TV ISF calibrated. Any good ISF guy can fix overscan.
Question about 2 tuner receivers
811 Software P262 Update Now Available!
