Honestly at this point you are better off with a stand along Slingbox.
Scott, did E* redesign the remote and remove the touchpad and it now has number keys and a dpad and looks like what shows in your attached picture? Or is that only for the 'onscreen/online' representation of the remote?So far (and remember this is just beta software) the Sling portion of the 922 leaves a lot to be desired.
First off it does not appear to be using Slingbox Pro HD technology. It only outputs in SD resolution and the PQ so far I dont believe is as good as a stand alone Slingbox.
Also it only outputs in 4x3 video mode, meaning the sides of your HD video is cut off (see the example picture below)
I am a Sling LOVER, I own 6 of them, and at the moment the 922 does not provide the true Sling experiance.
But in saying this again let me remind folks this is beta software, hopefully it gets better before its released.![]()
Gotcha. Me thinks they should build that remote for real (and make sure it also supports IR). Harmony users are screwed with the touchpad, and no IR, I'm pretty sure.That is the online remote you see when watching via dish.sling.com or via the Slingbox software.
Limited time offer
