922 EHD and TV2 | SatelliteGuys.US
922 EHD and TV2
nicmartim
20
SE Nebraska
Quick and easy question: Is it possible to watch recordings stored on my EHD on TV2? I cannot seem to find out how to do this. Thanks! :)
Set the Solo/Duo mode to Solo-PIP, and you will be able to see and play your EHD recordings on TV2. If you are on Duo mode, you will only be able to do this on TV1. However, note that once in Solo-PIP mode, you will not have a separate, independent feed to TV2. It will mirror what TV1 receives. The good part is that you get the EHD, Picture-in-Picture, and Swap working on both TV1 and TV2 while in Solo-PIP mode.
Owned or Leased
Hughesnet work?
