922 replaced | SatelliteGuys.US
922 replaced
dhickman
62
Central OK
I got my receiver replaced today.
I was able to transfer the settings from the old receiver to the new one via the remote.
It appears that the DVR side works great.
Now the problems are after 8 hours of running.
1. No logos
2. White screens on "Weather" and view bill
3. Sling does not work, keep getting "There was a problem communicating with your slingbox, please try again later."
I can control the box from dish.sling.com but no video.
I am close to being happy, now I just need the rest to work.
I am going to bed and hopefully by morning it will be working.
dhh
Got into work and check on the machine. Everything is working.
What is interesting is that the first unit was working out of the box. It started to malfunction that night.
I am supposed to receive my replacement tomorrow. Did the hard drive stop responding in your old 922? On the one that I have now, the DVR function simply no longer works, it is as if there is no hard drive there.
On mine it was random. Some shows was fine, then I would select a bad show and the screen went black and usually start working in 5-10 minutes or reboot.
Palladia DD - Pro Logic
211 USB Hub
