942 Installation Question | SatelliteGuys.US
Joe Searfoss
24
Wellsboro, PA
I currently have a DVR 522 with a Dish 500. I just purchased a new Sony SXRD HD TV. If I was to get a 942 so I could get the HD programming, is it just a receiver swap ? Can I just unhook the 522 and hook up the 942 without changing anything outside on the dish ? Also what would be required to receive the Voom Channels ?
Joe
Since 522 is a dual-tuner DVR, I assume you already have two RG6 cables coming in. So, I think this should be an easy swap.
As for getting VOOM channels, you will need a second dish pointed to 61.5 or 129.
quick question on an hd tv
Any know about line doublers or other S-video processing?
