942 L226 Release Notes | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,712
29,483
Newington, CT
Thanks to Jason at DBSTalk here at the release notes for the new L226 942 software.
* Off-air DTV tuning enhancement to reduce loss of signal occurrences and macroblocking under good signal cases
* Improvements to eliminate intermittent video jitter and audio pops
* Macroblocking reduction on playback of DVR events and in trick mode
* More robust recovery to acquire signal after reboot
* Corrected occurrences of black screens when using PIP and tuning off-air channels
* Corrected reverse at 300X speed function to allow rewind to beginning of the event or capture buffer
* TV2 programming pop-up enhancement for dual user mode and standby state
* Corrected anomaly causing above operating temperature warning pop-up appearance when not valid
Thanks for the update! Um...E* could try adding an off-air DTV enhancement where the OTA PG data doesn't continuously sh*t the bed. Post L2.26, I am still seeing "Digital Local" in the PG; it is still broken! Since I certainly don't need locals, I am in effect paying $5 per month for programming guide data that I am not receiving. Guess who is calling E* for a credit this evening.
522 Timer Question
Super Dish Install Problem...
