942 L282 to Spool Today! | Page 2 | SatelliteGuys.US
voripteth said:
My 942 is set to check for updates at 3am. How do I get it to download the update as soon as I get home?
http://www.dishnetwork.com/content/customerCare/technical/software_versions/index.asp
Updating Software
Verify signal from Point Dish:
Press the Menu button on the remote
Select System Setup from the Main Menu.
Select Installation from the System Setup Menu.
Select Point Dish from the Installation Menu.
Verify the signal bar is green and indicates "Locked".
Power the receiver off with the remote for 15 minutes to take the download.
Well, my wife's All My Children timer misfired for the 2nd day in a row (first time any timers have misfired) so this download will hopefully same me from further ass chewings. Downloaded L2.82 a short while ago and freeze problem after frame advance, and jumping to live after skip backward/forward appears to have been fixed. Haven't noticed any new problems...yet.
Scott, I think you can un-sticky this thread now that L2.83 goes into full phase release Thursday (according to the Dish Tech site):
Dish Tech Updates said:
12/14/2005: 1131 Software Version L2.83 for DVR942
Effective Thursday, December 15th, Engineering plans to spool the FULL PHASE of software version L2.83 for the DVR942 receiver. This is primarily a non-forced maintenance release available at ALL satellite locations.
At this time L2.83 will be the valid software version for the DVR942.
getting local channels after move?
Anyone noticing major pixelation with their 942?
