Getting 942 delliverd next week , I have 811 now with sw64 switch , do they need to change the switch ?Is the hd on 942 about the same as thehd on the 811? thanks harvey
To avoid confusion when you're posting in a group that often talks about both high defination and hard drives, "HD" usually means "high defination" and "HDD" is usually used to refer to a hard drive (hard disk drive).
