942 Woes..Help Please | SatelliteGuys.US
gutkin
3
I got Dish installed last Sat, 942 is one of my 2 receivers. Yesterday I notices the same problem, when I pull up my schedule It showed nothing to be recorded, after doing a hard reset the schedule showed up again, but now I cannot create more then 40 counters. Everytime I try it simply gives me the standard search screen and then no counter is created.
I've also had the 942 freeze on my three times in the last week. The freeze happens usually when I'm the Timer Management screen. Very frustrated here. Should I insist that Dish replace my 942?
Also can someone please post a link to a thread the describes that forced update trick?
What I have tried:
1. Soft Reboot
2. Hard Reboot
Yes , I would ask for a replacement . My two 942s don't do that at all. They work pretty much flawless. IF you mean timers when you say "counters", I have 75 timers listed right now and that is very light since it is summer. I record more than that when the networks shows are new during the regular season.
Skipping - Only on first hour of recordings
Problems With Certain Transponders
