99% quality no signal | Page 2 | SatelliteGuys.US
well come to find out it was my reciever I had a 905 reciever in the closet that someone gave me and hooked it up. works good but I think the battery is dead loses everything when unpluged. so on to the next problem. I'll do some reading .
Sorry its not a 905 but a 920.
hope it isn't the battery, otherwise it will have lost it's Unit ID which is needed for subbing :(
To check:
Options>6>5
Check Line A - there should be a 12 digit Unit ID - this number is also on a sticker on the back of the receiver, hope they match!
I think ATS can fix it if you send it to them Services
To check:
Options>6>5
ATS has no more replacement motherboards for the 920's.
Country Bunpkin Project #2 (positioner)
Help!!!First Time Big Dish Setup (Not looking Good)
