Voom upgraded my OTA antenna last week. Overall I am extremely happy with my Voom service now. I went from not having any local network coverage to 17 local channels found when I scan OTA signals now! They upgraded me from the Sensar II to a ChannelMaster 4228 amplified 8-bay antenna, at no cost to me. I do have a few questions though which I hope you can all help me with:
First, even though I now do get signal from my local Philadelphia networks, the OTA signal strength is very low across the whole board. For example, with the Sensar II I was only able to receive one local Independent Channel (WFMZ 69). However, the signal strength for this channel was almost always 99. Now, with the CM 4228, I still get the same channel but it peaks at only 81. This channel broadcasts from only 4.2 miles away from my house according to AntennaWeb. Now of course I would trade loosing some signal quality on a local Independent station for coverage of my local networks every time. But I am wondering if this lower signal quality on a close station when going from a Sensar II (which apparently wasn't even installed properly), to a large amplified antenna sounds correct?
Secondly, the fact that I only get ABC channel 6 very sporadically, even thought I do get CBS 3 and NBC 10 all the time seems strange to me. According to everything I've seen online, the antenna installer, and Voom these stations all broadcast from the exact same location. Also, if I check right now:
Thirdly, There are some channels which have very high signal strengths compared to the channels I do get, however they always show the "no signal" message. I have verified they are both broadcasting digital signals, not analog, and I am also almost certain that they both are found during the local channel scan. Examples:
. Thanks in advance for your help.
- Channel 3 - signal strength 61 (reception is perfect)
- Channel 6 - signal strength 69 (black screen; "no signal"; sporadic picture with heavy pixelation)
- Channel 10 - signal strength 81 (reception is perfect)
- Channel 57 (WPSG) - signal strength 70 ("no signal")
- Channel 62 (WWSI) - signal strength 97 ("no signal")
- Channel 12 (WHYY) - signal strength 33
- Channel 23 (WHJS) - signal strength 55
- Channel 44 (WMCN) - signal strength 36
- Channel 51 (WNJT) - signal strength 56
